Adding texture to DWG, unique issue.
2 ANTWORTEN 2
Nachricht 1 von 3
422 Aufrufe, 2 Antworten
I exported a 3DS Max to a DWG and then imported that DWG into Revit. I have the option to "Edit-in-Place" the DWG and then texture shows up. However, when I "Finish Model" the texture disappears. I've tried managing styles, visibility/graphics, etc. I just don't know what else to do.
2 ANTWORTEN 2
Nachricht 2 von 3
yurikim
als Antwort auf: Anonymous
Thank you for your posting @Anonymous.
How about if you create this as a family? If you create a new family and bring DWG into this family > Explode, then you will be able to apply the material. If this family is loaded back into the project, you will see the material applied.
Hope this helps.
Cheers,
Yuri Kim
Product Support Specialist, AEC
Nachricht 3 von 3
als Antwort auf: yurikim
Thanks for the response. I tried but I get this error..."Import contained 3D data or points which can't be exploded. Only 2D data was exploded."
