Adding spot coordinates to asset families
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1301 Aufrufe, 3 Antworten
I had built a sample architectural revit model with some assets like fire hydrant, camera, air conditioner, Lift call button.
I need to extract spot coordinates of this assets in a list of tables say excel. i.e. i dont want to manually put all spot coordinates and extract manually.
Since this is a sample model manually could be done but actual model contains more than 1000 assets.
Please can anyone help me or any idea how it could be done.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
PS: Im working on revit 2018.3 Smiley (fröhlich)
Nachricht 3 von 4
You can do this with Dynamo using FamilyInstance.Location node.
Nachricht 4 von 4
als Antwort auf: barthbradley
Hi barthbradley,
Thank you so much for your response and suggestion. That worked fine. I actually from http://dynamobim.org/forums/topic/familyinstance-location-node/ for FamilyInstance Location.
and i made a network like this below you can see:
The coordinates did matched (. I want to report it in excel, what additional steps I need to do. I'm not so expert in dynamo, just tried the steps what was written.
Secondly, some warning came above python script. Do i need to correct it?
Smiley (fröhlich) Smiley (fröhlich) Smiley (fröhlich)
