I am trying to edit the default brick-top annotation family in Revit 2024 to have a solid filled-region for the hatch. Every time I create a new filled region type, and set the pattern to be 'solid', Revit crashes with the message below...
"Revit encountered a serious error. The current action could not be completed.
It is recommended to save your work in a new file and audit it in the most recent version of Revit."
Is this a common issue with solid patterns in families?
I've seen issues in the past related to the material editor crash Revit. Did you submit a crash report if Revit offered up a dialog to do that? Did Autodesk's system reply with a suggested fix? If they think a recent update will resolve an issue that's usually the response you'll get.
What is the family name you're editing so we can test that family specifically vs testing randomly against other files or something from scratch.
Also it is tedious but is your PC up to date with patches etc? Did you install the recent 2024 update yet? Do you use any 3rd party software that could affect the outcome? I ran into a family that Enscape "hated", for example, and crashed Revit.
I've run into situations where "nothing has been changed" but IT deployed a MS service pack or new video driver so things that I'm not aware of can impact how the big R behaves.
Hopefully a restart of the PC, and special beverage put you right?
Steve Stafford
