Adding "Places" folders to a Deployment
jcaporasoZNPSQ
jcaporasoZNPSQ
I'm tryin to find out how to add custom Places to a Revit 2021 deployment. I've exhausted several hours pouring over ini file recourses and many a failed google searches. I found some suggestions about editing Windows Registry Keys, but that doesn't seem to be a practical solution for our needs.
We have a deployment for Revit 2019 that currently will do this, but it was set up by my predecessor, so we're unsure of how he accomplished this.
Not the file paths we needNot the file paths we need
constantin.stroescu
you can add additional Places - to search for from other Libraries...for example I add my custom library of Editable Families..
  • click on + to add custom libraries and then 3 points icon to set the path to the folder where the library is hosted
name the library :
and when opening Families,for instance you will find your custom Place into the List (into Look in):
Constantin Stroescu
jcaporasoZNPSQ
Yes, I've had no trouble adding these Places to Revit. My trouble is that I can not get them to save to the local user's ini file or add these locations to a Deployment
