Adding profiles to floor panels
24 ANTWORTEN 24
GELÖST
Nachricht 1 von 25
Homecad2023
1373 Aufrufe, 24 Antworten
Hi there
I would like to add profiles to floor panels such as bottom plates as shown in attached image.  Not sure the best way of doing this
Thanks in advance
Tony
24 ANTWORTEN 24
Nachricht 2 von 25
als Antwort auf: Homecad2023
Model it the same way it will be constructed in the real world.  What is that element in the real world? Beam? Thickened Edge?
...maybe the Slab Edge Tool could be employed here.
Nachricht 3 von 25
Use slab edge tool with a custom profile.
Nachricht 4 von 25
@Homecad2023 wrote:
Hi there
 Do you mean Curtain Wall Panels?
Nachricht 5 von 25
Homecad2023
als Antwort auf: barthbradley
In the real world it would be a 2x4 or 2x6 plate.  I guess a slab edge would work but I have no luck in creating slab edges.  Anyone have a good example that applies here
Nachricht 6 von 25
https://www.youtube.com/watch?v=YxX15GHX8Zk
Nachricht 7 von 25
Why incorporate this into the floor as a "slab edge"? Why not beams for this? Seems you'd have a better BIM Model that way.
...are these plates constructed separately from the floor or are they embedded into the floors?
Nachricht 8 von 25
Homecad2023
Slab edge is a good solution however how would you have it as part of the floor instead of always having to add it after
How would you add beams as part of the floor?
These plates are added before the floor gets installed but it might as well be part of the whole assembly since they happen almost at the same time
Nachricht 9 von 25
Are they modular floor panels?
Nachricht 10 von 25
Homecad2023
als Antwort auf: ToanDN
They could be modular
Nachricht 11 von 25
Well, it's your planning, but if it were me, I'd keep the plates as separate elements. Think phases of construction and disciplines.
Nachricht 12 von 25
Do you have any specs you could share with us about the construction? Maybe photos?
Nachricht 13 von 25
Homecad2023
The construction is basically wood floor joists with a 2x4 on flat around the edge.  I think my original image somewhat explained it
Nachricht 14 von 25
So basically this:
Nachricht 15 von 25
Homecad2023
Yes! now the plates can be 1, 2 or 3
Nachricht 16 von 25
Double or triple sill plate?  Why?
Nachricht 17 von 25
Homecad2023
Long story but site some times prefer the double plates to hide the anchor bolts and on rare occasion some clients prefer the 3 plates
Nachricht 18 von 25
Why not just make the stem walls taller?
Nachricht 19 von 25
Homecad2023
Stem walls?  not sure if I understand the terminology
Nachricht 20 von 25
It's what your sill plate is anchored to.  Google it.
