Adding Perimeter Drainage to Basement
Hi all,I want to add a perimeter drainage in a basement as per the image attached. Any ideas welcome, thanks.
BEE_Design
Hi vcendoya,
Does it have to be confined to a system? 😛 If not then I would just be tempted to sweep that along the path with the correct slope.
Good Luck!
SY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
chrisplyler
Do you really need to model it? I wouldn't.
I would just use a detail line and a notation to call it out on a plan view. Then I would cut a section view through a suitable bit and use detail elements to draw it as your picture shows.
If you do want it modeled and part of a system so you can schedule it and stuff, I would make a new pipe type and use it to model the system, and then in the section view I would still use detail items to make it look how you want it too look instead of like round pipe.
