I have been trying to add a room parameter to a window tag in Revit, so that when I tag the window, the room it is in also shows in the tag. I have tried adding a label to the window tag but the room parameter is not available, is there a quick way to solve this?
Or is there a way to add editable text to a window tag, so that once I have placed the tag I can edit the text of each instance?
Thank you
