Hello. Is it possible to add a material to material list even if it is not exist in the drawing. I have an automatic sliding door and I need to write down to material list that there is a power unit in this door. This power unit is inside the door, you do not see it, so I did not bother to draw it. However I need to add it to the material list, and also other elements that are hiding inside the door. If you have a solution for this will help me. Thanks
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
There are other ways too which do not involve modeling the actual element (such as using dummy nested families into the door and associating those to a Family<type> parameter) but you might want to keep it simple.
Key schedules work best for finishes, hardware and accessories lists...and the like
https://www.youtube.com/watch?v=objFhLsP_Nw
