Adding nodes to a curved surface to apply a adaptive components to?
1 ANTWORT 1
Nachricht 1 von 2
562 Aufrufe, 1 Antwort
I am trying to create a complex standing seam curved roof which curved along the section and in plan.  For this reason the change in direction can only be achieved using 3 point linear adaptive adaptive component.  The problem I face is that where the divided surface interfaces with a corner it does not place a node so the pattern stops at this point.  Please see the screenshots attached to better understand.
1 ANTWORT 1
Nachricht 2 von 2
Corsten.Au
als Antwort auf: Anonymous
1. those pattern is following the surface, and surface is not allowing to complete the panel..
2. your best bet would be to create a surface to get the complete panel, and later
you cut geometry from the surface ....
Corsten
Building Designer
