Adding new materials to Library
7 ANTWORTEN 7
Nachricht 1 von 8
tstewart
1049 Aufrufe, 7 Antworten
How to add materials to a Library so they can be used in a model?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: tstewart
Nachricht 3 von 8
tstewart
als Antwort auf: barthbradley
It did not work for me, so I must have done something wrong. HELP?
Nachricht 4 von 8
What didn't work for you?  What did you do?
Nachricht 5 von 8
tstewart
Adding new materials did not work the way I tried.
Nachricht 6 von 8
List the steps of your workflow.   I have no idea what you've done.
Nachricht 7 von 8
tstewart
  • ANNOTATE
  • REGION
  • DRAW (RECTANGLE)
  • PROPERTIES (EDIT)
  • SELECT FOREGROUND PATTERN (MODEL)
  • CAN'T FIND .PAT, OR NEW PATTERN PHOTOS (SEE BELOW)
Nachricht 8 von 8
No wonder you are lost. Those steps have nothing to do with adding new materials to  library. They are not even close.
Did you even bother reading the information I provided to you in your other thread?
https://forums.autodesk.com/t5/revit-architecture-forum/adding-materials-finishes-to-walls/m-p/96476...
Also:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
