Adding materials/finishes to Walls
3 ANTWORTEN 3
Nachricht 1 von 4
tstewart
1819 Aufrufe, 3 Antworten
How to add finishes (i.e., metal panels, siding, stone, etc.) to walls' surfaces?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tstewart
Look under the stock Assets that comes with Revit.  There is one using a similar Image. You can assign it to a Material to be used by your Wall Finish.
...you can also use these Images in Revit in your Material's Appearance Asset.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
Nachricht 3 von 4
tstewart
Where are the Stock Assets in Revit and how would I add the attached photos to the Materials library?
Nachricht 4 von 4
Did you happen to see the Link I provided above?
...not sure where you are getting stuck. Are you unclear about how to  navigate to the Asset Browser, or how to insert or change an Image?
