Has any one experienced strange Revit group behavior when adding mass elements to a Revit Model Group?
I am able to add a mass element to a Revit Model Group.
However, when I insert an instance of that group, the mass element does not appear in the instance.
Upon review, it appears to stays fixed in the original model group location. When I select the group instance; its "linked" to the original with the mass element.
We often use mass elements to create custom elements in our home designs, so this could be troublesome.
Is this a known Revit issue? And if so, is there a workaround?
Thank you,
Cathy
