Adding Light into an Imported Revit Model
sydney_ghiglione1
Observer Observer
sydney_ghiglione1
Observer
Observer
So I had to make several light fixtures in SketchUp because Revit didn't have any models that resembled them. So I modeled them in SketchUp, brought them to Formit, then into my Revit model. And they look great! The only issue is that they don't emit any light. I know in SketchUp you can add the light source itself, can you do that in Revit too? I just don't know how to make it light up.
GHASEM_ARIYANI
hi
1-open new family template > Metric/Imperial Lighting Fixture.rft
2-insert tab :
if you have a Skectup file: Import CAD > Change File of type to SKP, then open.
if you have a Revit family file *rfa: insert tab > Load family and loaded your family.
3-set Light Source on the Light Geometry.
4-Settting Light Source Definition on the Ribbon.
5-Set Light Source Parameter.
6-Load into Project and Worked.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
handjonathan
Hi @sydney_ghiglione1
Thanks a lot for posting your question to the forums!   Has the solution suggested by @GHASEM_ARIYANI helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
