I have just downloaded free trial of Revit Lt, I'm trying to add a level and the button is greyed out, is this because its a trail and you don't have access to the full package?
Kind regards
Alan
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
No there must be another reason. Check if you are working in elevation or section. You can't create levels in a floorplan.
If you want to learn more about levels see this autodesk article.
