Adding Label to Grid bubble
Message 1 of 9
hello
i'm trying to add label for M_Grid_head to type building name but when i load into the project i can't change the label text it just appears as a question mark!!!
can anyone help??
Thanks in advance
Replies (8)
Message 2 of 9
syman2000
Is your label shared parameter? If it is, then you need to add shared parameter to your project.
Message 3 of 9
Are you talking about something like this?
Project:
Family:
Message 4 of 9
First Thanks for your reply
but no this is not what I mean 😔
attached is an example for what I mean
Message 5 of 9
i had yes a shared parameter and loaded it into project but still reads as question mark and won't be modified
Message 6 of 9
martijn_pater
Do you have the shared parameter as project parameter? (manage --> project parameters), add it for grid category.
edit: actually as @barthbradley showed above, that should resolve it...
Message 7 of 9
it didn't 😔
Message 8 of 9
martijn_pater
Does the project parameter show in properties when you select one of the gridlines? Could you give it a value?
Message 9 of 9
- Add a label in the grid bubble symbol family and associate it with a text Shared parameter
- Add the same Shared parameter to you project parameters and assign it to Grids category
