Adding Entourage in elevation views
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Sahay_R
2048 Aufrufe, 3 Antworten
Today I was helping one of the Interior Designers add human figure to an elevation view to add scale. Rather than have her endure RPC entourage families, I took it upon myself to create filled region families by -
1) creating the filled region as a detail item and nesting it into an Entourage family. Inserting this family was a pain because reference planes parallel to the elevation needed to be there to host the family
2) switched the family in Step 1 to a Generic Model - no difference. Worked just as well (or rather, just as badly)
3) I finally broke and removed the nested detail items, saving them as Detail Item families. They work in elevations like a charm.
Even though I have found a workaround that works, I would like to know if there is, possibly, a more elegant solution to this problem.
Thank you.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Sahay_R
What you are doing is adding entourage elements to furnish the view, not the model, so using Detail families is appropriate.  I would do the same.
Nachricht 3 von 4
@Sahay_R: You did good. Smiley (fröhlich)
Nachricht 4 von 4
Sahay_R
als Antwort auf: barthbradley
So there was no other option?
Wow. I feelz schmaaartt.
Rina Sahay
