Hi, as you can see from the screenshots I am having trouble when trying to add edge to mass. I am trying to add edge from one Vertex to another can this cause the problem. I want to add an edge like red line in screenshot how can I do?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Thank you very much, you can find the picture of the mass I want to add edge and the project file in the attachment.
Sorry. Being that it is such an abstract shape, it's not clear to me what you are trying to achieve as an end result. But, you can't there by adding an Edge. The Mass won't allow an Edge along that surface.
Out of curiosity, what are all these oddly-shaped mass elements anyways?
I apologize for causing confusion. I am trying to design a shell-shaped structure consisting of hipped roofs. I am an architecture student, so what I am doing now may not mean much :D. I tried to show the way I was trying to do it on Max.
It's hard to envision what you are building. I'm guessing all these Masses will become building components at some point in the design/planning process. If so, do you have a photograph or something that shows how the architectural construct looks in the real world?
I suggest to use a workaround by creating two extra faces on the Mass element, as shown in my following rough screencast:
https://knowledge.autodesk.com/community/screencast/4a18ae8f-56db-472a-99c1-f785207061bd
Constantin Stroescu
That was exactly the answer I was looking for. Thank you for your help. Regards.
