Adding drawn, checked and approved by to revision schedule
1 ANTWORT 1
Nachricht 1 von 2
jcruickshanks
620 Aufrufe, 1 Antwort
Hi, I'm creating a titleblock and I've been asked to include revision number, description, drawn by, checked by, approved by and the date of issue.these are all to be in the revision schedule, so that it matches with the autocad titleblock.
I can easily add the other three fields but is it possible to add drwn, chkd & appd?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: jcruickshanks
You can use Issued to and Issued by for Drawn by and Checked by.  Not sure about Approved by, all of what you asked, but particularly Approved by are normally on the titleblock, but not in the Revision schedule.
Or use Issued to for Drawn by/Checked by, and Issued by for Approved by.
Last but not least, if Drawn by / Checked by / Approved by for each revision are not the same for every sheet, then the information cannot be from the revision schedule.
