Message 1 of 9
01:11 PM
I am planning to draw tilt-up walls in revit. I imported the floor plan from CAD and started using wall command to draw walls. But I have some doubts. Generally tilt-up walls have embeds and ledger beams at the roof level to hold or connect the structural system of the building. So my question is How do I add those embeds and other features to the walls? I have plans to use this model in Navisworks for clash detection but getting the REVIT model right is the topmost priority. Plesae could you help me with your suggestions and ideas rom your experiences?
Attahced is an image. The marked up items are which I wanted to add to the walls in revit.
Thank you
