Adding casing around a radius cased opening.
1 ANTWORT 1
Nachricht 1 von 2
glkirk
431 Aufrufe, 1 Antwort
I would like to add the stock Revit casing around an interior radius cased opening I made.
I tried it using the "model in place and using the profile. But it only came out as half inch wide instead of the 3 1/2" wide.
Can anyone steer me which direction to make this?
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
cbcarch
als Antwort auf: glkirk
Try setting the current Workplane to the vertical face of the wall and then apply the casing.
I'm thinking maybe it was placed with the Floor Plan/Level set as the active/current Workplane, so it applied itself
sideways (to the underside of the arched opening) instead of on the vertical face?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
