Adding annotations to a family that display on a plan/elevation
5 ANTWORTEN 5
Nachricht 1 von 6
lr-PAYNE
327 Aufrufe, 5 Antworten
Hi all, I was attempting to try and get something like this to work. I want to add a parameter to add a text annotation that displays when viewing in a view or plan.
Reason behind it was I want it to appear in internal elevation views as a alternative labelling mechanism where I can put a label on each element of the family. Below is what I am trying to achieve. GR = Guard Rail
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: lr-PAYNE
It's a limitation. A workaround is to Tag the Family in Elevation View IN THE PROJECT.
Nachricht 3 von 6
lr-PAYNE
Ok so its not possible to do that in the family? Reason being is that i want to save time having to tag the family in each view and also the family is made of multiple parts that I want labeled. So toilet, guard rail, back rest etc. I assume you cant have a tag for each part of the family if its within the same one?
Nachricht 4 von 6
Create each components as a shared family, nest them in the master family, then you can TAB to tag individual components in the project.
Nachricht 5 von 6
The components would need to be nested, shared Families within the Parent Family. Then you could TAB-Select and Tag them individually in the Project.
Nachricht 6 von 6
...Tag All will also tag Nested, Shared Families. That might work as an alternative to TAB-Selecting one at a time.
