adding a slab under a garge
rclement
rclement
i was wondering why when you add a floor and choose the inside line of the wall
it really7 doesnt go to the inside edge and when you hit the check it askes to delete part of the wallwhy doesnt it
go to the ind=side wall?
when i use rectangle then it does pick each corner and now remove the wall message
Mohamed-Nassar
Because it attach the wall to the top Hight
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Sorry, but I don't understand the question. Can you post some screenshot showing what you are seeing?  The RVT did help.
martijn_pater
Do you mean using pick walls? You can untick "extend into wall (to core)"... Not sure if that's what you're after.
_Vijay
I don't have 2021, better show some screen shots.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
