I need a reminder. We have more than the standard Disciplines on my current project. How do I add a "Discipline" to the list of Disciplines listed as choices? I need to add some like Kitchen, Security, Signage and so on. I don't want them as sub categories.
Thank You
Nardo
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
if it is for Browser organization then create a different parameter and assign it to Sheets and Views categories. If it to delineate work responsibility then use worksets.
When I am putting in the Parameter it shows as a independent parameter. It isn't going in as a Discipline. It doesn't show up in the Disciplines list. How can I get the new parameters to show up in the existing Disciplines?
Nardo
Pardon me, but I'm a little confused by your intermingling of the terms: "Parameters" and "Disciplines". But, I think you may be wanting to add a project parameter of the text type to your views. Right?
Nardo
The Discipline parameter is hard-coded and cannot be changed. The new parameter should just be a Text instance parameter assigned to Views and Sheets.
I was trying to add Disciplines to this list. But I guess this list is Hard Coded. So that's out. See below
Yes, I get that. It sounded as though you were even aware of that already, and was trying to remember out how to add a "Discipline" named text parameter field to your view properties. This would easily be accomplished by adding it through Project Parameters, as Toan and I suggested. Each view then could be assigned a unique discipline of your choosing. You'd just enter that name in that project parameter field that you created and assigned to the View's properties.
@barthbradley wrote:
So, I guess I was right. Right?
You left the question for me or OP? Either way, yes.
