Revit cannot read SHX font. You need to find an equivalent TTF or OTF (true type OTF not postscript OTF) typeface.
Close alternative: Architxt.TTF and Archtitl.TTF
Hi @tpreisler
Revit uses the fonts in your Windows directory. When you set up a text style, the font should show up as an option.
Revit only works with True Type Fonts that are ANSI Character-based. (These are fonts that can be used in Microsoft products such as Word.)
If it is .shx then it will only work with AutoCAD and you will have to substitute a ttf font for it in Revit.
Yes, as @ToanDN mentioned you will need to convert OTF fonts to TTF fonts: See HERE for information on how to convert.
To install or reinstall a font in Windows:
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
ARCHISEL.TTF, @Viveka_CD?
Can't find. Could you post link or file itself, please.
You're wonderful. Many Thanks.
iHere you go @barthbradley
Archisel.shx and Archisel.ttf can be found at the below links
http://www.cad-corner.com/textstyles.php
http://www.caddsolve.com/font-files.html
http://designfxdirect.com/buy.html
Note: Some are free downloads and some paid
Viveka CD
Hi Viveka Devadas i installed a specific text to my windows 10, but when i try to change the text type in Revit i don't see that text as an option.
I'm not sure what did i miss.
@Viveka_CD wrote:
Hi @tpreisler
Revit only works with True Type Fonts that are ANSI Character-based. (These are fonts that can be used in Microsoft products such as Word.)If it is .shx then it will only work with AutoCAD and you will have to substitute a ttf font for it in Revit.
- Open the Fonts folder, either through Control Panel or by opening the Windows\Fonts
- Click File menu > Install New Font.
- In the Add Fonts dialog box, select the drive and the folder where the new font file is located. A list of any font files that are found in the selected location will appear in the List of Fonts box.
- Select the desired font
- ARCHISEL TTF, ARCHSTYLE TTF and the fonts suggested by @barthbradley are alternatives if you want to try.
Thank you.
