adding a column on sheet issues/revision in revit
23 ANTWORTEN 23
Nachricht 1 von 24
3930 Aufrufe, 23 Antworten
Hi Everyone,
Just wanted to ask if it is possible to add column/s on sheet issues/revision in revit?
gerald
23 ANTWORTEN 23
Nachricht 2 von 24
als Antwort auf: Anonymous
Sure it is. Just add parameter fields to the "schedule".
...what are you wanting to add?
Nachricht 3 von 24
saman.nejad
Looking to do the same. Have you found a solution?
Nachricht 4 von 24
als Antwort auf: saman.nejad
Total how many columns do you need?
Nachricht 5 von 24
saman.nejad
als Antwort auf: ToanDN
9 columns to be exact. Rev., Emission Type(E.T.), Description, Designer, Drafter, Ver., Apr., Aut. and Date.
Nachricht 6 von 24
Is Emission Type value per project or per sheet?  If per project then you can add a Project information parameter to the schedule.  Plus, enter Designer/Drafter/Ver into a single field such as Issued By.  Apr. = Issued to.  Not sure what Aut. is but you can use Project information > Author.  There you go.
Nachricht 7 von 24
saman.nejad
The Emission Type, Aut. (Autorized By) values is per project but the Rev., date, ... are per sheet values.
Thanks for your help.
Nachricht 8 von 24
Then what shown above should work perfectly fine..
Nachricht 9 von 24
akshaprojects
als Antwort auf: barthbradley
Create a new field is unavailable. Edit(or delete) an existing one is greyed out. What do I need to do?
Nachricht 10 von 24
als Antwort auf: akshaprojects
What information do you need to show in the new column?
Nachricht 11 von 24
akshaprojects
@ToanDN
I need a column for 'Checked by'. I know there is no existing field in revision schedule for that but if I want this added, how do I do it? I wouldn't mind renaming 'Issued to' field to 'Checked by' if at all it was possible.
Nachricht 12 von 24
@ToanDN
Seems redundant.  Don't you have Checked By as  Sheet's parameter already?
Nachricht 13 von 24
akshaprojects
@ToanDN
First of all, my initial query was that I am unable to add new parameters to Revit's in-built Revision Schedule. Is there a way to do this? I created a shared (type) parameter 'Checked by' in the sheet but it does not appear as one of the available parameters in the revision schedule.
Nachricht 14 von 24
@ToanDN
I know what you initial query is and I know user's parameters cannot be added to revision schedules for the time being.  My question for you was why do you need to add [Checked By] to your revision schedule when the built-in [Checked By] parameter already exists and can be shown on the sheet's titleblock?
Nachricht 15 von 24
akshaprojects
@ToanDN
Now I understand your previous query. So, the 'Checked by' parameter from sheet is used as Engineering check in our office and it exists on our title block. The checked by on the revision schedule is for drafting check and is checked by different person each revision.
What I have done for time being is to create a 'calculated' field named 'Chkr' and equalled it to existing 'isued by' field.
Nachricht 16 von 24
@ToanDN
I thought you said you had no fields available.  If [Issued By] is not being used then why don't you just use it and rename the Schedule Header to Chkr instead of adding a Calculated parameter, which will show the exact same value?
Nachricht 17 von 24
ramakrishnan.n
But is it not stupid from auto desk part in not providing to add fields for revision column , i ve drawn by , designed by , apprd by col in addition to issue by and issued to columns. how to insert all this , autodesk support to answer
Nachricht 18 von 24
als Antwort auf: ramakrishnan.n
Edit your titleblock family, edit the revision schedule, add fields to it.
Nachricht 19 von 24
ramakrishnan.n
but in revision schedule there is no provision to add extra field .. the filed should be sheet wise parameter not project wise.
Nachricht 20 von 24
ramakrishnan.n
can you please show how to add extra fields in revision schedule im using revit 2022
