Adding a ceiling not available in Ceiling Plan view
varia024
varia024
So I have this issue that I can not figure it out what it is.  Im trying to add a ceiling in the first floor of my building on the Ceiling Plan View. My automatic ceiling does not work even tho I have close rooms, instead it makes a different shape that is not the same as the room. and when I sketch the ceiling is not showing it anywhere, not even in a different view or section or anything.
And then I tried to add a ceiling from the floor plan view and the automatic ceiling works fine and the ceiling sketch allows me to draw and complete a ceiling, and when i change to the ceiling plan view the ceilings are right there!
So, basically I can not add any ceilings from the ceiling plan view but  in the floor plan I can.   Please Help!!
Set Work Plane and make sure you have the Level selected, not something else.
varia024
Thank you so much, it worked! @ToanDN
