Adding 10mm joint to brick pattern
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2253 Aufrufe, 3 Antworten
I have created a pattern as follows bellow but it doesn't show the 10mm joint.
The bricks are bespoke 199.16x65mm.
Any help would be appreciated.
0, 0, 0, 0, 65
90, 0, 0, 65, 99.58, 75, -65
3 ANTWORTEN 3
Nachricht 2 von 4
tgrantdelawie
als Antwort auf: Anonymous
Check out this website
http://www.cadhatch.com/
They have an excel generator which will do exactly what ya need!
Hope that helps.
Nachricht 3 von 4
hugha
Try this:
;        Written by HatchKit Team Edition
;        HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2019-06-15
;-Time                                   : 11:27:21
;-HatchKit Team Edition Version          : 3.1.11.2776
;-HatchKit Team Edition Output Filetype  : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*Brick,RUNNING HORIZONTAL bond=1/2
;%TYPE=MODEL
90,0,0,75,104.58,65,-85
0,0,65,-104.58,-75,199.16,-10
-90,199.16,65,75,104.58,65,-85
180,199.16,0,104.58,75,199.16,-10
hth,
Hugh Adamson
www.hatchkit.com.au
Nachricht 4 von 4
als Antwort auf: tgrantdelawie
I have horizontal joints of 10.18mm and vertical joints of 10mm,
which row of the cad correspond to the vertical arrangement?
cheers
