Added material to wall
7 ANTWORTEN 7
Nachricht 1 von 8
jillL24YD
272 Aufrufe, 7 Antworten
I made a generic concrete wall and it is adding a material in section and I don't know why since it is not in the wall it's self.  Anybody know what might be causing this?
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
nozci
als Antwort auf: jillL24YD
Your wall material will be between wall boundaries. It is normal.
Nachricht 3 von 8
azad.Nanva
use the surface material:
Nachricht 4 von 8
jillL24YD
als Antwort auf: nozci
I only have one material and it is the right width. It is adding an addition material making the wall thicker.  I have never had this happen before, that's why I can't figure it out.
Nachricht 5 von 8
jillL24YD
als Antwort auf: azad.Nanva
I have the surface and cut material set to concrete.  It is only showing up in section view.
Nachricht 6 von 8
nozci
Did you measure your wall thickness on the pan view?
Nachricht 7 von 8
azad.Nanva
post your material element like me.
Nachricht 8 von 8
jillL24YD
