Good afternoon Revit users,
Is there a way to add +/- tolerance beneath then dimension line, without having to open the dialog box to manually add it every time.
Is there a way to create a dimension family or modify a dimension family where I can add the +/- beneath the dimension line? I got the +/- as a suffix on the same line but I need it separate.
See attached pic to see what I'm going for.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Here is a detail Revit manual family you can add control text below the dimension.
