Hi everybody, I've noticed Sofistik has managed to update shared parameters automatically and I wonder If someone can give me a hint to replicate this with other parameters that we might consider to be useful.
For instance, the rebar mark number gets updated automatically:
i) This is my 212 rebar shape
ii) Then its detail component element (Rebar shape as 2D lines) house the same number in the "Anno_mark" parameter
iii). Then if I change the mark number, the detail component changes immediately:
I looked up the detail component family and I dont see any formulas and I could notice that It's a non-editable parameter.
Any hints to add shared parameters that update automatically?, I believe it's not necessary for parameters to be non-editable to make this workflow possible, but If you any hints on that too is more than welcome
Best Regards,
Miguel G.
If you meant to sync Anno_Mark of a detail component with Mark of a model component then you cannot do it automatically in Revit. Dynamo maybe a semi-automatic approach.
If you meant the 212 in the circle changed to 412 when you change Mark from 212 to 412? Because it is a tag that shows the Mark parameter as a label. It is a basic Revit functionality.
@miguel.gutierrezD74CZ wrote:Any hints to add shared parameters that update automatically?
It almost sounds like you may want a "Reporting Parameter", but I'm kind of lost in all the weeds here.
But FWIW, here's what I'm referring to:
Thanks for your prompt reply Toan, That's what I'm looking for, to synchronize a default parameter with a new shared parameter. SO you recommend to dive into the backend sea using python or c# language to accomplish this? I can manage to create shared parameters and write data into that one from the "mark" parameter using Macro or Dynamo node but how exactly can I leave both of them synced afterwards?
Best regards
You will have run the Dynamo script whenever you need to sync them. That's why I called it semi-automatic.
Hi barth, thanks for answer me
I'm stuck here too, it seems I will need to check about "Reporting parameters" too to head me into the right direction
Best regards,
Yeahp, That's what I bore in mind too, however Sofistik has accomplished a really cool stuff. I would appreciate if there is any software product developer we can ask for advice. It will ease some tedious task when working with sheets, views, among others components.
Cheers!
