Hello, Anyone knows the procedure to create a shared parameter and add it to system families like walls?
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
The steps to add a shared parameter to a wall or another system family is not different than doing the same for loadable families.
Project Parameters > Add > (select a parameter from your shared parameters file) > select the group (text, for example) > select the category (walls, furniture, etc...)
To create a shared parameters file, please refer to this article: https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-94EA2B8E-2C00-4D29-8D5A-C7C6664DE9CE
Thank you Alfred, i will take it as solution. What about how to create the shared parameter that automatically refers those families at its specific local or space within a model? Do you have tips for that?
I don´t understand the question. If you are referring to being able to report in what room or space a family is located, that is not a function of shared parameters. It's just a feature of some categories that can report its location in a schedule.
