Add SF to schedule column using calculated values
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
StephMarsh
959 Aufrufe, 6 Antworten
I need to have my "Areas" round up in my tags and schedules. I am doing occupancy calculations.
My tag works fine. I uses the following value..
When I make the schedule I use the same format. The issue is that I can't get the "SF" to show up.
For this line the load is 100 sf per person. The Room area is actually 200.7 SF. but the area column says 200 SF. I created the column to "roundup" the area.
Now I just need to add the SF to the value.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: StephMarsh
Why not create the calculated parameter as Area type instead of Number type?  Then use the formula = roundup (Area) and format it normaly.
Nachricht 3 von 7
StephMarsh
als Antwort auf: ToanDN
Then I get inconsistent Units
Nachricht 4 von 7
Nachricht 5 von 7
StephMarsh
als Antwort auf: barthbradley
I have always struggled with formulas.
Nachricht 6 von 7
roundup(Area / 1 SF) * 1 SF
Nachricht 7 von 7
StephMarsh
SUCCESS!!!!!! Thank you for helping me so fast
