Add Parameter to Material
2 ANTWORTEN 2
Nachricht 1 von 3
hliS658H
187 Aufrufe, 2 Antworten
How can I add the parameter "bump" to the wood material?
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: hliS658H
Some of the material already have preset definition and you can't add configuration to it. You can choose alternative which will give you bump like the Red Oak or White oak.
Nachricht 3 von 3
Corsten.Au
Hello
Each type of material have different properties. you can see the differences below ( some examples).
Maximum properties are I think in " Generic Material ".
Replace the asset and choose what to begin with and modify the material.
Or simply create a New material and then use Generic ( replacing the asset ) and customise it.
GenericGeneric
Generic Material.
GlassGlass
Glazing / Glass ( no bumps, cutout etc )
MasonryMasonry
Masonry ( bump, cutout,  translucency etc )
MetalMetal
Metal
Mettalic PaintMettalic Paint
Metallic Paint
PlywoordPlywoord
Plywood
Use Replaces This Asset option to choose the Material to begin with.Use Replaces This Asset option to choose the Material to begin with.
Cheers.
Corsten
Building Designer
