Add parameter group
Add parameter group
qixingc
Add parameter group
qixingc
Does anyone know how to add a group parameter that is highlighted in yellow?  For example I want to add group parameter "Asset Information" so that I can add some relevant asset information parameters.
Thank you for your help!
RDAOU
@qixingc
 No, you can neither add nor edit the existing.
kadmonkee
that is only to allow you to sort where a parameter will be grouped in your properties palette.
you can create a Shared Parameter "ASSET INFORMATION and place it under the Identity Data group and then apply it to the category(ies) it would apply to
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
