Hey Guys,
Haven't had to do this in awhile and struggling to find anything on the web.
Im trying to add a new tile pattern that i have found online. below is the code, i cannot remember what the process is... Do i add this into Revit or do i need to open up CAD and create this then add it in?
*Floor Tile Pattern ;%TYPE=MODEL 0, -.1,0, .3,.3, .2,-.4 90, 0,-.1, .3,.3, .2,-.4 45, 0,.1, 0,.4242640687, .2828427125,-.1414213562 135, .2,.3, 0,.4242640687, .2828427125,-.1414213562 135, .3,.4, 0,.4242640687, .2828427125,-.1414213562 225, .3,.2, 0,.4242640687, .2828427125,-.1414213562
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
1. Copy that text
2. paste in notepad
3. save that notepad with extension " pat " Example "Tile1.pat
4. In Revit, select a hatch ( filled region) , Duplicate it and edit it..
5. While editing it gives option to import hatch pattern, there you import " Tile1.pat " file
6. looking at that pattern text, its a " MODEL " pattern.. it means you can use it for 3d elements
like floor/wall and it will be visibile in 3D
hope that helps..
hello, you can refer to this LINK. thanks
