I added a Key Name to a Key Schedule but forgot how to get the main schedule to recognize the new name. I know it must be simple....
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You inserted a Data Row into the Key Schedule and populated the Parameter Values next to it? And the Key Schedule is inserted into the Main Category Schedule? And the Parameter Fields in the Key Schedule are in the Main Schedule?
...or did you rename the Key Schedule? Unload - reload.
Answer to your questions in order are : Yes, not sure, and Yes.
My problem appears to be with being sure the main schedule is reading the key schedule, i.e., inserted into it
Key Schedule will show up as an Available Parameter Field in the List. That is, available in the Main Schedule.
...the Key Schedule must exist for the Category being Scheduled.
Thanks. I think my problem is / was I had 2 Key Schedules ??? In any case, I re-added the parameter and that is working now.
