Hello to all members,
perhaps you can help me solving an strange issue with the Add-In "DB Link".
Situation: adding new customized parameter to project wether shared or project Parameter. Exporting to SQL Express Database, than Import to Excel. Everything works fine, customized parameters exist in Database and Excel. Adding values or deleting values in Revit, Export to SQL and import in Excel, values not existing any more.
BUT the problem is: deleting a parameter (notice: not the value, the parameter on ist own) and than exporting to SQL and importing in Excel, the parameter still exists, both in the database and in Excel.
Has anyone an idea?
Thanks in advance.
F.Kopp
Hi Aukett,
Thank you for posting this on the forum,
Have you by any chance any screenshots of it or a recording og the steps you're taking?
Whenever I use the DBlink it seems to work as supposed to, so if possible could you record your steps and send me a link?
Best Regards,
Jacob Westergaard
Autodesk Product Support Team
Revit/CAD Specialist
