Add door to curved curtain wall
4 ANTWORTEN 4
Nachricht 1 von 5
l.yong1
607 Aufrufe, 4 Antworten
Hi there,
Does anyone know how to add door to curtain wall?
Thanks Lillian
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: l.yong1
@l.yong1
  1. Load a Curtain Wall Door type >>>
  2. select the Curtain wall panel you want to replace >>
  3. unpin it >>>
  4. From the Properties Palette Type Drop Down menu >>> replace with the door you loaded
  • If you want the door itself to be curved, you will need to model it curved
Nachricht 3 von 5
Regular Door or Curtain Wall Door.  If regular Door, replace the CW Panel at the Door location with a Basic Wall Type from the Selector - then host a regular Door to the Basic Wall panel.
Nachricht 4 von 5
l.yong1
Thank you R. I have tried this previously. But the door does not stay curved on the wall. How do I model it as curved?
Once again thank you
Nachricht 5 von 5
There's no curved CW Panel either.  How did you model the panel? As a Basic Wall?  If so, why not do the same for the Door (e.g. use a curved wall for the door)?
