Add dimensions to structural column to schedule
4 ANTWORTEN 4
Nachricht 1 von 5
Jonathan.russo5LGGT
1759 Aufrufe, 4 Antworten
Figure this should be simple but why isn't dimensions available field for structural column schedule? I am going to type the dimensions for each column type individually in the description?
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: Jonathan.russo5LGGT
@Jonathan.russo5LGGT
The b x h parameters of the column section need to be Shared Parameters...Edit the family and change them to Shared Parameters, then you will be able to schedule and/or tag them in the project
The Height/Length is available in the Structural Column OOTB parameters...Length/Cut Length or can be calculated using Base and top constraints, volume, area...
Nachricht 3 von 5
Is this what you are looking for?
Nachricht 4 von 5
To get the data in the schedule the parameters in the respected family supposed to be shared parameters, create shared parameters and assign those that to the dimensions in the parameters tab
Nachricht 5 von 5
...or are you looking to Combine Parameters like this:
