ADD CUSTOM PARAMETERS TO A MODEL LINE
Hi everyone, how are you?
I have a problem that I don't know how to solve. I need to add custom parameters that I have created to a bunch of model lines. I need this because some of the walls finishes in the model that I'm working on are represented by model lines, they are not model like a wall type, so I need for example to add a parameter so I can assign a room or a sector of the building to these model lines so I can know their hight when I export them to excel and get the area. This is just an example, I would like to add any parameter that I can think of to the model lines.
Does anyone know how to do this?
Thanks!
If you create the lines using Generic Model line based family, you will be able to add parameters, such as a length, which you can schedule.
