add control to lighting fixture placement
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
linkboy
321 Aufrufe, 3 Antworten
Can I add a control /instance parameter so as to move lighting fixture and pendant cable (cable length unchanged , controlled by other parameter) altogether as one part "A" in relatively to the reference plane?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: linkboy
Sure.  Align and Lock all Geometry to Reference Planes and then drive the Ref. Planes with Labeled Dimensions.
Nachricht 3 von 4
HA! I've got your family open, but I am confused by your instructions. How do you want it built?
Nachricht 4 von 4
linkboy
als Antwort auf: barthbradley
I did it as you advised. I can control the length of cable and the elevation of fixture now. It is to use bypass the annoying sloped roof. Thanks!
