Add blank rows in Sheet Index
kjskoog
Message 1 of 9
kjskoog
Looking to add blank rows in sheet index to separate the disciplines. Been playing with it and cannot find a way to do it. How can I accomplish this?
Thank you.
Kory Skoog
CAD/BIM Manager
Kory Skoog
PM/BIM Manager
Replies (8)
Message 2 of 9
Sort by disciplines, set as header, and add blank row before data. All are
within Sort and group settings.
Message 3 of 9
kjskoog
Thank you for the reply. I created fields for each discipline but still cannot get a blank row between the discipline. I get a blank row between all of the rows when I select blank line. Also selecting the header box gives me a header between each row as well. I am learning to create schedules but some reason this part of it is not going very well.
Thank  you
Kory Skoog
CAD/BIM Manager
Kory Skoog
PM/BIM Manager
Message 4 of 9
Alfredo_Medina
Activate "blank line" in the Sorting & Grouping tab, as shown below.
Message 5 of 9
FGPerraudin
Agreed, and do not tick the "blank line" box for further sorting!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 6 of 9
Steven.A.King
Please tell me how you accomplished this!
Message 7 of 9
Base12
Can you post an example of how this turned out?  I either get a blank line between every row, or none at all, regardless of the combination of checking "blank line" boxes.  Also, I guess you made your own Project Parameter for Discipline since it's not included (why not??) in the default Sheet parameters.
Message 8 of 9
Mike.FORM
We created a Sheet Series parameter in our template and use that for sorting the as shown.
You do not need to check the header box in Sheet Series. We also have the Sheet Series hidden in the Formatting tab.
Message 9 of 9
Base12
I see, thanks for the quick reply!
