Please forgive a newbie for asking what might seem as easy stuff. To me this is difficult
I want to do this:
-Make a family, say "recessed downlight".
-Make types, say "white finish" and "black finish".
-Add accessories, like "driver 350mA" and "driver 500mA" in order to choose the driver I need in the Lighting fixture schedule later on.
As of now, I dont need the driver to show in the Revit Model - I just want to be able to select it in the Schedule in order to get a complete and correct equipment list.
Hoping for some clearifying answers
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You're looking to create shared parameters.
If you don't need it modeled, and it is just information, then put that information into one of the in-built Identity Parameters of the Family Type. All those Parameter Fields are available to Schedules. Additionally, there are in-built Instance Parameters that all Families have when place in a Project, such as "Comments" and "Mark". Those are also available Parameter Fields in Schedules.
Hi, Martjin
Thank you for answering. I guess this has to do with parameters and maybe nested families.
I think what I am looking for, is a schedule were the differerent accessories are listed along with the component itself - and that I can toggle the different accessories on or off as I want. I nearly made it yesterday:). If I succeed or nearly succeed I will post a file to show what I have done!
Hi, Barthbradley!
Thank you for answering. It seems to me that I must use parameters as you say, but I also think I need nested families, that I need to nest the drivers and other accessories into the components I am making. I am a lighting designer and the components in questions are mostly luminaires with drivers, filters and such. The goal is to end up with a schedule where everything is specified and priced. I would like the accessories to appear as a dropdown menu or similar, something like this:
That would be done by way of Nesting Shared Families into Host Families.
Look into Family Type Parameters. They would be perfect for this.
(6) Add choices to your Revit families with Family Type Parameters | LinkedIn
