Add a visibility instance parameters to a Level Annotation family
EdMilbourn
EdMilbourn
Good day all
I'm trying to add a 'yes/no' visibility instance parameter to a level annotation family.
I have added the parameter I want but once loaded into the project it is not available as an 'option'.
What I am trying to achieve is to be able to make the elevation value visible in some views but not others.
Using family types (eg 'level with elevation' / 'level without elevation') changes the type in all views.
Maybe I have fundamentally misunderstood how annotation families work.
Thank you 🙂
RDAOU
@EdMilbourn
Feature is not available...you can post it on ideas if you wish
Alternatively; Place a dummy level datum with a different symbol/label then use view filters to control visibility in different views
