Hi ,
I'm trying to reduce my number of tag in my plan and I was wondering if I can add a new leader/arrow from a tag by category on a same object/family close to it (for exemple: two room mirrored and have the same toilet...)
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von JasonKunkel. Gehe zur Lösung
Unfortunately, a tag can only apply to a single placed element in your model. There would be issues of what data to pull if you could tag multiple elements if you could tag more than one instance.
Workarounds are empty text box with a leader placed beneath the tag; a "blank" symbol that basically does the same thing also works.
that's what I thought ! thank you for your answer !
@JasonKunkel wrote:Unfortunately, a tag can only apply to a single placed element in your model. There would be issues of what data to pull if you could tag multiple elements if you could tag more than one instance.
I have the same issue. It would be nice if you make an Idea and ask for this.
