add a formula inside schedule
9 ANTWORTEN 9
Nachricht 1 von 10
TomasoCardia
1280 Aufrufe, 9 Antworten
Hi all,
I'm looking for a solution to solve my problem to "create a schedule that show me the lenght of mullions"
So, I tried to create a parameter on a parametric family, but i doesn't work.
As alternative I want to transform the "area" of mullion on lenght.
So, the question is:
Is it possible add a formula that transform the Area on a lenght ?
I know the number to subdivide the area to obtain lenght, but I don't know how to put inside the schedule on Revit
( without export on Excel :leicht_lächelndes_Gesicht: )
Thank you!
9 ANTWORTEN 9
Nachricht 2 von 10
TomasoCardia
als Antwort auf: TomasoCardia
I did it.
on a schedule configuracion--> fields it is possible to add a Formula.. Yeah!
Nachricht 3 von 10
Diego.Faria
Although it's possible to do by formula, I think you should use the built-in "Length" parameter. It works just fine.
Diego Faria
LinkedIn
Nachricht 4 von 10
Alfredo_Medina
Are you sure that you really need curved panels and curved mullions?
Nachricht 5 von 10
TomasoCardia
als Antwort auf: Alfredo_Medina
what does it mean? I have to build curved panels on curved mullion (profiles)
Nachricht 6 von 10
Alfredo_Medina
It means that for fabrication and economic reasons, usually these curved facades are fabricated as short straight segments that simulate the curve.
Nachricht 7 von 10
TomasoCardia
it is not that case.
Anyhow, I think that the software have to follow the construction not the opposite. In this case is a limit of Revit
Nachricht 8 von 10
Alfredo_Medina
No, it's not a limitation of the software, but a solution to facilitate construction and build with under the constraints of a budget.
You can model curved panels and curved elements that represent mullions, yes. I was just wanting to confirm.
Nachricht 9 von 10
TomasoCardia
I'm not agree with you.
So, in your opinion, Revit it is not a tool for the designer, but a "tool-teacher" that impose you how to design. I think is a limit of Revit, because Revit can't permit to design something that in a reality will be built, and in large scale as this project.
Nachricht 10 von 10
@TomasoCardia
Why didn't you post your related questions in one thread so that people can understand the history and follow it?  Below are what I am referring to.
what is the "Area" on a parametric object
parameters and schedule for a parametric mullion
how to see a special parameter on a schedule
