Adaptive Spandrel Curtain Panel
3 ANTWORTEN 3
Nachricht 1 von 4
526996629
237 Aufrufe, 3 Antworten
I'm modeling a spandrel curtain panel as shown in the image. (I don't want the way using single panel and changing the material)
Howver this could only fit in the rectangles. If my curtain panel is irregular, I have to create an adaptive curtain panel. However it seems there is no template for that (for Revit 2020). I hope to have such custimized panel fit in all shapes just as system curtain panels.
Any suggestions for this template and any suggestions for modelling this spandrel panel?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: 526996629
There is no adaptive curtain  panel family template, only generic adaptive, generic pattern based, and curtain panel pattern based.   What do the curtain wall and panels look like?
You can also assign a basic wall type with multiple layers to curtain panels, create parts from it and exclude air layer to create a true cavity.
Nachricht 3 von 4
526996629
als Antwort auf: ToanDN
Suppose the curtain wall has a filleted corner, how would you deal with the panel at the corner? Or maybe there is another panel which is a triangle one, would you create several different family to fit in the different shapes?
For the system panels, we can directly change to any shapes, but custimized panels cannot.
Nachricht 4 von 4
Did you read the previous reply fully? Assign a basic wall type to the curtain panels.
