Hello everyone,
I'm trying to model an adaptive component for a facade. This component is closing and opening due to sun rotation by a dynamo script. While the rotation problem seems to be solved, I can't parametrize the whole panel as if it should maintain its proportion whichever will be the grid dimension. I'll post the model (Revit 2019) to make you better understand what I mean.
I'll be grateful for any feedback and please, correct me for any mistake I made in the model.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Actually no, and this is one of the problem I can't solve. One solution will be to make the archs attached to the reference lines of the frame, but I can't. And, as well, I can't attach the void to those lines. It's becoming quite tricky....
Ok, I solved for the triangular panel attaching them to the reference lines, but still I can't do the same for the solid of the frame.
You are on the right track; however, you have 2 or 3 minor issue.
