Hello everyone,
I try today to create a complex voulme with 2 nested family but I can't create the volume and I don't know why.
Theses are the steps I dis :
- I create a central path with points
- I copy to 1000m on Z axis the path
- I create 2 random paths edges
- I divide the paths with the same number
- I create another adaptive generetic family with 4 adaptive points to select the central path, then the central path +1000mm in Z axis, edge one and edge two
- I place the component created and repeat it alongs the paths
- I try to create a volume and error
Can someone ever had this issue ?
What do you mean by "Volume"? Do you mean to say that you can't create a "Form"? I examined your file and I can't figure out what you are doing - or trying to do. Do you have a picture showing what the finished product is supposed to look it?
This?
...use TAB-Select to select Ref. Lines.
...or this:
...or this:
