Adaptive family: Unable to create form element: self-intersecting or singular geometry would result.
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
kirkpatricktFKQC2
1829 Aufrufe, 14 Antworten
Hello I'm trying to create an adaptive wall that can curve in both the x, y, and z axis however my profile does not seem to want to create a shape even when its in a straight line. Any help would be greatly appreciated
Beschriftungen (5)
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: kirkpatricktFKQC2
something like this?
Nachricht 3 von 15
kirkpatricktFKQC2
als Antwort auf: ToanDN
yes perfect! how did you do it?
Nachricht 4 von 15
Do you want the wall to be curved like in my picture or segmented like your path?
Nachricht 5 von 15
kirkpatricktFKQC2
your picture is exactly what I was going for, I need it to curve along a path and then down like you have it.
Nachricht 6 von 15
Then place the adaptive profile family on every node, select them (not the green segmented path, in fact you don't need the path at all) and create form.
Nachricht 7 von 15
kirkpatricktFKQC2
perfect thank you so much
Nachricht 8 von 15
kirkpatricktFKQC2
thanks for the help earlier, it doesn't seem to want to host to the wall now, is there something I'm doing incorrectly? I'm going into plan and clicking along the edge but I get the error "Could not generate references for Family Instance." should I create a new post for this?
Nachricht 9 von 15
Your adaptive profile family is not hosted properly at the 1st point.  Fix it and it will place just fine in the project.
Nachricht 10 von 15
kirkpatricktFKQC2
I fixed the first adaptive point however it still isn't placing at all, I get this error
is there a specific way to place the points? I'm not experienced with adaptive families. I appreciate your help
Nachricht 11 von 15
Can you share the updated family?
Nachricht 12 von 15
kirkpatricktFKQC2
here is the updated family, thank you
Nachricht 13 von 15
- Set all 12 Adaptive Points to Instance (xyz)
- Set the family to Always Vertical
Nachricht 14 von 15
kirkpatricktFKQC2
works now, thank you
Nachricht 15 von 15
Albert.Maduro
This is the answer I am looking for which also solved my problem of revit refusing to form a solid for 2 different profile with reference line as their path in between
